GMC Jimmy high RPM's at idle?
Old Oct 3, 2013 | 11:24 PM
bdude273's Avatar
bdude273 is on a distinguished road
Default GMC Jimmy high RPM's at idle?
Hey,
My GMC Jimmy runs at around 1000RPM's when sitting, after about 5 mins it goes down to 600. Its about 12 degrees celsius out idk if that effects it. I cleaned out the throttle (it runs fairly smooth; very minimal shaking) with some carb cleaner and it runs better but still revs high. Should it be revving at 1000 or not?
Old Oct 4, 2013 | 01:37 AM
richphotos's Avatar
53°f or 12°c is chilly, so its really not out of the question to be up around 1000 at that temp. the fact that it drops after about 5 minutes to normal is indicating that its the choke that is on.
Did it just start doing this now that the temp is starting to fall? or has it always done this, even when it was hot/warm outside?
Old Oct 4, 2013 | 05:56 PM
bdude273's Avatar
it has always done it whether its 27 degrees or 5
bear159
Dec 7, 2023 09:11 AM
mcdevin1973
Oct 5, 2014 02:52 PM
vonholt53
18
Feb 23, 2013 03:04 PM
wollefdoog
Oct 27, 2011 11:13 PM
londonmazda
Oct 19, 2010 02:15 AM
