Got the 02 motor in the 98 but wont stay running
Well spent all day putting the motor in the truck. Started the day by tapping the hole for the larger knock senser dropped the motor in the truck, connected the torque converter and after that everything went so smooth finished up then tryed to crank and nothing. Just would run the gas I poured into the intake out and then shut off. I can hear the fuel pump turning on and I took the gas lines back apart and there is pressure at the spider but will not stay running please any Ideas. Thanks
did you check for codes? make sure there are no bent pins on your spider wiring harness(the plug)
I am assuming you have the intake tubed put on with the maf sensor plugged in?
cpk sensor I am assuming would be ok seeing as it runs when you pour gas in...
Good point on the intake system. If the MAF sensor is still plugged in, but the intake hat is not on the throttle body, the PCM will not see the airflow and will not put in the right amount of fuel to support an engine start.
Well I got home from work today and dicided to start by changing the spider assembly. And it starts and stays running this is wonderful I thought, some white smoke came out but that was expected concidering the motor has sat for a year or so. This made me so happy considering this is the first motor I have ever changed out. But then I stared to drive it and the best way I can explain it is its shaking. Its got new plugs, feul filter, and new spider assembly. I just dont have alot of money left and I was wondering were to go next feul pump or timing I have a new set of wires to put on it tomarrow I just got dark so fast. Ichecked the feul pressure with a backyard gauge I found In the shed and its saying I only have 30psi at the fpr would that cause the shakes or would the timing be the culprite if the wires dont fix it tomarrow. Any sujestions please? THANKS for the previous info It helped alot.
30psi isn't enough to even start the engine, but I suspect your gauge is wrong. I would recommend getting another gauge and checking it again. Also remember to flush out the gauge (it should have a bypass line).
Which spider did you use? The one from the '02? The newer spider is considered an upgrade for all 96+ engines and will offer much more reliable fuel delivery over the older design.
Thanks again for the info but unfortunetly the new feul spider that I had was for a 98 so it was not the new design. Although the new design was what I took out, I think it may have been bad or even clogged up but theirs no way to know now. Anyway I geuss my next step will to be go get it diagnosed. Because I have found that just guessing can get costly fast. Also, this was a gauge i just found laying around, so i may have been faulty. I can hear the fuel pump kicking on when i start the truck. I'm now thinking after replacing the wires and spark plugs that it may be the timing?? Or fuel pump going bad. That's why I've decided to just go for the diagnosis & not waste anymore money than what I need to. Again Thanks for the info, very helpful.
This same thing happened to me when I changed out my motor the injectors were fine when it ran before then #5and 6 injector stopped working when i put the motor back in.
I would suggest pulling the upper plenum and pulling the injectors out the lower intake and connect the fuel and harness back up to the spider and unplug the ignition coil.Then have someone spin the motor over to make sure all of the injectors are spraying fuel.If and injector is not spraying it will definitely run rough and shake.
