Harmonic Balancer
Old Nov 7, 2010 | 01:33 PM
appliancguy's Avatar
appliancguy is on a distinguished road
Default Harmonic Balancer
I'm trying to reinstall a distrib and when the #1 piston is at the compression stroke the timing marks on the crank pulley are way off. What now??????? New hoirmonic??????
Old Nov 7, 2010 | 01:49 PM
What are you working on?
Old Nov 7, 2010 | 02:00 PM
Default o crap
95 blazer 4.3 sorry
Old Nov 7, 2010 | 02:05 PM
If your distributor has the horizontal towers, then follow the EDI engine timing thread found in the Tech Article (DIY) Index link in my signature. The newer EDI system does not place the #1 cylinder at TDC-compression exactly. There are two marks you need to line up.
Old Nov 7, 2010 | 05:20 PM
Default Wtf???????
Define exactly. I got piston to TDC then moved crank approxe 60 degrees to align both marks on crank pulley. Using A plastic tube the piston appears to half way down the cylinder. Am I crazy....well about this?
Mike
Old Nov 7, 2010 | 05:24 PM
That does sound excessive. From what I remember, it should be 10-15 degrees of rotation. It has been awhile though. 60 degrees sounds like way too much.
Old Nov 9, 2010 | 07:08 PM
The harmonic did slip. The new one lined up perfect with the notches on the timing cover. I'll try and start it tonight. I left the light on under the hood and the battery is stone dead. This has to be OBDII, its has a crank sensor and did disply PXXXX codes. The vin suggest its a CPI system. Can I upgrade this to MFI?????? The timing cover is plastic but the upper intake is large and metal.
Mike
Old Nov 9, 2010 | 07:13 PM
You have the older CPI engine which means there are no upgrades.
Glad you got it figured out. Hopefully it starts without an issue for you.
Old Nov 10, 2010 | 08:21 AM
Default Shes Alive!!!!!!
It lives!!!!!!!! Started right up an d runs great!!!!!!!!
Thanks......I will keep the CPI and deal with it.
Mike
mech cb
Mar 28, 2010 12:31 AM
wilds_dog
Feb 16, 2010 09:16 PM
Katmandu
Aug 22, 2009 10:50 PM
1blkblazer422
Jun 22, 2009 03:04 PM
thehustler211
Apr 14, 2009 06:06 PM
