harmonic balancer installation?
Old Mar 20, 2011 | 04:40 PM
jbordi's Avatar
jbordi is on a distinguished road
Default harmonic balancer installation?
Will I need to stop the engine from rotating when installing a new balancer? This will be my first time doing one of these. So far the instructions I have found just say to install the new balancer using the installer tool, no mention of motor rotation before balancer completely seats?
2001 S10 Blazer 4.3L
THANKS in advance!
Old Mar 20, 2011 | 07:00 PM
TZFBird's Avatar
TZFBird is on a distinguished road
I'm pretty sure the balancer is keyed. I've never had one off, but all the ones on other vehicles I've worked on have been.
Old Mar 20, 2011 | 08:02 PM
jbordi's Avatar
yes, you are right about it being keyed. Does this eliminate the need to hold the fywheel from turning while tightening the balncer to the crankshaft snout? Sorry if this a dumb question.
Old Mar 20, 2011 | 08:11 PM
Frog's Avatar
Frog is on a distinguished road
If you cannot achieve the required torque without the engine rotating......then yes you will have to use something to keep the engine from rotating.
I have always used a flywheel turning tool to hold it and then torque the bolt. Some use a prybar or something but, I would not.
Old Mar 21, 2011 | 05:22 AM
TZFBird's Avatar
I thought you were just worried about the timing mark being off if the crank rotated in relationship to harmonic balancer. Sorry if I got confused by your question.
Old Mar 21, 2011 | 07:55 AM
jbordi's Avatar
No problem, I should have been more clear in my post. Thanks for input.
mech cb
Mar 28, 2010 12:31 AM
wilds_dog
Feb 16, 2010 09:16 PM
Katmandu
Aug 22, 2009 10:50 PM
1blkblazer422
Jun 22, 2009 03:04 PM
thehustler211
Apr 14, 2009 06:06 PM
