Head Gasket or Radiator?
Old May 9, 2014 | 10:02 PM
KptKrunch's Avatar
KptKrunch is on a distinguished road
Default Head Gasket or Radiator?
So, I've got oil in my coolant. I was thinking Head Gasket myself, but after thinking about it, could it be my Radiator?
2001 Blazer, 2wd 6cyl 4.3L
Oil in the coolant
The reason I think it may be my rad, is the fact that there is no white smoke, no power loss, no overheating, no other signs of issues. I know I have a leak on the Intake Manifold, but there is WAYYYY too much oil in the coolant to be leaking from that without power loss. At one point, I ran through a quart of oil in less than 3 weeks.
What do you guys think about it? Rad or HG?
*i hate life if its HG*
Old May 9, 2014 | 10:22 PM
bigkhans's Avatar
bigkhans is on a distinguished road
Check you oil cap for foam, and then check your oil for foam. If a head gasket has failed letting coolant into your oil then your oil will foam up quickly and should be fairly easy to diagnose. If not then I would consider changing the intake manifold gaskets.
Old May 9, 2014 | 10:46 PM
KptKrunch's Avatar
The big reason I'm thinking Rad is the oil cooler in it. It's leaking way too much oil into the coolant to be the intake. It's close to a quart every two weeks.
All of the signs you said don't exist. No foam, at all.
Old May 10, 2014 | 12:52 PM
bigkhans's Avatar
Ah, ok my Baja had the same oil cooler set up. I would change out the radiator or have a shop fix it.
limited edition 1
Jan 27, 2023 11:07 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
J.R. Clay
Mar 17, 2011 08:22 PM
LJ809
Apr 25, 2010 06:02 AM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
