HEAD GSKT REPLACEMENT HELP!!!
Old Jan 25, 2009 | 02:44 AM
cnile8989's Avatar
cnile8989 is an unknown quantity at this point
Default HEAD GSKT REPLACEMENT HELP!!!
Okay i have a 2000 gmc jimmy 2-dr, 4.3L V6. Every 3 or 4 weeks, i have to completely refill my radiator with coolant....BECAUSE IT DISSAPEERS!!! Its not leaking from any visible location so im guessing i have a blown head gasket. Although it has no water/coolant coming outta the exhaust and no smoke. DOES ANYONE HAVE ANY INFO ON DOING THIS I HAVE NEVER ATTEMTED ON A JIMMY!
Old Jan 25, 2009 | 11:05 AM
rriddle3's Avatar
Default RE: HEAD GSKT REPLACEMENT HELP!!!
Have you checked the appearance and level of your oil?
Old Jan 25, 2009 | 11:43 AM
bigwes's Avatar
bigwes is an unknown quantity at this point
to me it sounds like u have a freeze plug blown out.
Old Jan 25, 2009 | 03:27 PM
mrafindley's Avatar
mrafindley is an unknown quantity at this point
or intake leaking at front or rear
Old Jan 26, 2009 | 08:52 AM
jeepmudbogger's Avatar
jeepmudbogger is an unknown quantity at this point
mine was doing the same thing. if you get under it, look real close. mine was leaking from the intake gasket in the back of the motor and i had to get in real close to see any leak, but it was there. it took me 7 hours to change
Old Jan 28, 2009 | 10:22 AM
cnile8989's Avatar
nope nothing in the oil and levels are fine. i am seeing slight leakage under the chassis. none out the exhaust either.
echo1
15
Aug 28, 2012 07:56 PM
amart
Dec 24, 2011 04:51 PM
Thrakhath
Nov 1, 2011 08:22 PM
J.R. Clay
Mar 17, 2011 08:22 PM
ant2297
Oct 27, 2009 12:44 PM
