Can Someone ID this Casting number
Old Jan 27, 2009 | 05:25 PM
mandng0's Avatar
mandng0 is an unknown quantity at this point
Default Can Someone ID this Casting number
Does anyone have access to find out detailed info on GM casting numbers?
The number on my block is 14893638 and I cant find anything on it for the world...
Checked mortec and didnt see anything...
Old Jan 27, 2009 | 06:29 PM
rriddle3's Avatar
Default RE: Can Someone ID this Casting number
What exactly are you trying to find out?
Old Jan 27, 2009 | 11:03 PM
mandng0's Avatar
the year of the motor.. and what type it is exactly.
I cant find it anywhere.. all i know is that its a sbc350
Old Jan 28, 2009 | 06:40 AM
Where on the block was this number? It does not seem to be a valid block casting number. Are you sure the numbers are correct?
Do you see any number/letters on the front of the passenger side cylinder head mounting surface on the block?
Old Jan 28, 2009 | 07:24 AM
mandng0's Avatar
I took the numbers off the rear of the block on the passenger side right above the bell housing...
Didnt see any letters or anything.. Ill have to look again later today
Thanks guys
Old Jan 28, 2009 | 07:43 AM
Do you have some pictures? Did you clean this area off with a wire brush? Any other casting identifiers?
14093638 is a valid block ID and comes across as a 89-93 350 V8 OHV, RWD, TBI, roller lifters, center bolt valve covers, high swirl intake ports, right hand dipstick, one peice rear main seal.
Old Jan 28, 2009 | 12:53 PM
papacope's Avatar
what database did you use to look up the block number?
Old Jan 28, 2009 | 12:55 PM
Google.
ChevyHick01
Jun 18, 2011 06:27 AM
scbird94
May 24, 2010 08:04 PM
PROJECT85K5
Dec 6, 2009 10:55 PM
joedonack71
Feb 8, 2009 01:17 PM
2drblazer
Jun 29, 2008 02:04 AM
