Head Swap
Old Sep 15, 2008 | 11:03 AM
cejay825's Avatar
cejay825 is an unknown quantity at this point
Default Head Swap
I have searched forever and I'm confussed as hell !!
I have a 95 "w" code engine,Can I use the good heads 96 + (461?) on my 95 with the cpi ?
Old Sep 15, 2008 | 08:10 PM
smdepew1976's Avatar
smdepew1976 is an unknown quantity at this point
Default RE: Head Swap
you can but did the 95's intake have the vortec bolt pattern? if not i found a thread somewhere that claims you can have them redrilled
Old Sep 15, 2008 | 09:18 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
I just looked around at parts and a 97 and 96 vin W head would not fit your 95 vin W. Im guessing a 95 probably has roller rockers since both the 96 and 97 specify not for roller rockers where the 95 doesnt mention it.
Old Sep 16, 2008 | 03:57 PM
Hanr3's Avatar
http://www.babcox.com/editorial/ar/ar39840.htm
any more questions?
If you do use the newer heads you will also need the corresponding intake manifold. Watch for that info as you read through the article.
T...K21
Aug 2, 2013 07:25 AM
Rumblur
May 22, 2013 03:23 PM
echo1
15
Aug 28, 2012 07:56 PM
J.R. Clay
Mar 17, 2011 08:22 PM
SHA-BOOM280
Oct 20, 2009 01:49 PM
