Heavy duty or standard duty flywheel
I was looking for a flywheel at napa for my 98 jimmy 4x4, There are 2 choices the standard duty flywheel $41.49 That I have 2 of already from previous motor swaps or the heavy duty $95.99 before my discount
Would this heavy duty flywheel cause any thickness issues? or any other issues i have not thought of? The H.D. total O.D. diff. is .127mm smaller then the standard flywheel, I dont think that much of a diff. would cause a issue, But thats why i ask
standard flywheel
# Flex Plate Teeth : 168
Balance Weighted : Yes
Crankshaft Diameter : 2.00"
Flex Plate O.D. : 14.130"
Manufacturer : Anchor Industries
Manufacturer Part Number : FA-101
heavy duty flywheel
Flex Plate O.D. : 14-1/8" converts to 14.125" slightly smaller
Manufacturer Part Number : FA-101HD
standard flywheel
heavy duty flywheel
Right on the heavy duty flywheel worked out great, I was able to start on it after lunch i dropped the y-pipe, front/rear d/shafts, c/member etc. The flywheel was cracked in 2 places LoL thanks reman. motor comp. All in all it took me maybe 5-6 hours to swap everything out and back in, Plus i still had to work on cust. cars. THANKS again for the help swartlkk!
Fullsizeon38s
Apr 30, 2013 06:06 PM
motorcity blazer
Jun 21, 2011 12:27 PM
warhammer44
Suspension Tech
Oct 28, 2008 10:56 PM
14, 18, anchor, benefit, chevy, duty, flexplate, flexplates, flywheel, flywheelfa101hd, flywheels, gm, heavy, hevy, industries
