help
Old Apr 5, 2012 | 10:45 PM
herdman123's Avatar
herdman123 is on a distinguished road
Unhappy help
hello everyone, i have a 2001 chevy zr2 blazer. i am wondering what could be wrong with my truck, i have a rapid leak of antifreeze, along with poor acceleration and trouble starting, i recently had my distributer cap replaced, thinging that would help with the starting issues, i have had my fuel pump checked as well as my spark plugs, any ideas?
Old Apr 5, 2012 | 10:54 PM
50lb_cat's Avatar
I would start with the antifreeze issue. Are there any visible leaks? Does it smell like coolant from the exhaust? Is there coolant on the oil filler cap?
Old Apr 5, 2012 | 11:00 PM
herdman123's Avatar
well i have yet to take a closer look at it yet, i am going to spend the day trying to diagnose what is actually the problem, but yeah like i said with the rapid leak i put close to a gallon of water and antifreeze in my radiator and within five hours it has almost completely leaked out
Old Apr 5, 2012 | 11:49 PM
50lb_cat's Avatar
That is a serious leak. If you can't find any visual leaks then it sounds like the lower intake gasket failed. I hope you didn't let it over heat or you could have blown a head gasket! The lower isn't a hard job just time consuming.
Old Apr 6, 2012 | 12:27 AM
Rottidog's Avatar
A lot of people would say that IS the actual problem. If there aren't any visable leaks on the driveway etc then you're burning it off - hence the actual problem. That would cause crappy running conditions - burning coolant with gas & air.
Trouble starting - because antifreeze is being pushed into the cylinders after you shut it off.
What did the spark plugs look like when you changed them, what color, condition?
Does it smoke a bit when you start it after running to operating temp & shutting it off for awhile? If so then <what that kitty said>
