Rocker Arms.....
Old Apr 6, 2012 | 06:08 PM
MikeRo's Avatar
MikeRo is on a distinguished road
Default Rocker Arms.....
So i have a friend swapping his rocker arms his 2.2 s10 and he is really pushing me to do the same. He found this kit COMP Cams RPR201-12 - COMP Cams Magnum Rocker Arm Kits - Overview - SummitRacing.com and told me i should do it. However i am not 100% on the workings of engines. Will these fit?
searching the forum i saw this by [B]bigringtravis[B]:
Roller rockers are considered "adjustable valvetrain." Vortex 4.3s (and many other newer engines) have non adjustable valvetrain. So to run roller rockers of any ratio, you need to get the heads machined to accept them.
Its that accurate? and does it even apply do doing something like this kit?
School me on it guys
Old Apr 6, 2012 | 06:42 PM
I'm not too sure what the '95's have for rockers, but the newer motors use net lash setups that are not adjustable. They have a bolt that is drawn down tight & torqued in place to hold the rocker. If that is the setup you have in your truck, you would need to have your heads machined to accept screw in studs.
Old Apr 6, 2012 | 07:11 PM
MikeRo's Avatar
Hmm i guess i will have to do some more research. It wouldn't happen to be listed anywhere specific would it?
I found these:
Two styles of rocker studs were used on the 4.3L engine. Since teh "screw in" style with postive stop shoulders is most common, thats probably the reason why you got those instructions. However, some heads still used the older style "press in" studs, which require the manual adjustment.
-or-
1992 to 1995 Vortecs ALL used a net lash system with screw in studs and self aligning rockers
but still unsure, any more insight in that brilliant mind?
Old Apr 6, 2012 | 07:56 PM
Just looked up the article Rebuilding the Chevy 262 by Doug Anderson and the net lash rockers came in full use in '95 so you'll have the bolt in rockers.
Old Apr 6, 2012 | 09:08 PM
MikeRo's Avatar
So if i want to do something with the rockers i would have to get the heads machined. Because i have net lash rockers and the new ones won't fit. Just need to remember all this facts about my truck.
neal
Engine & Internal
21
Jan 6, 2015 11:19 AM
Pyro_fighter
Nov 13, 2012 03:23 PM
2000TAHOEMAN
Jan 1, 2011 08:27 PM
magnum434
Sep 21, 2009 10:47 AM
Baja Blazer 85
Engine & Internal
Jun 1, 2009 08:55 AM
