Help
Old Sep 3, 2012 | 05:55 PM
rjhvetter's Avatar
rjhvetter is on a distinguished road
Angry Help
Hi i have a 2000 zr2 blazer when i first start it it runs ruff at low speeds at full throtel it runs fine.and when it warms up it clears up i have put a used egr valve,crankshaft sensor and disribitor still run ruff at light throtel. rjhvetter@yahoo.com
Old Sep 3, 2012 | 10:55 PM
Rottidog's Avatar
Why the email addy? You're not going to check back & would rather we email you?
Anyway... search around here, there have been more than a few recent posts about rough starting, low performance when cold & better when the engine warms up. I just can't remember them off hand.
Try searching for rough cold start, bad idle etc.. change up wording, sit back & read a lot because I know the answer is there.
1st thoughts would be O2 sensor/s, cat, TPS, EGR - Not used but clean & replace the gasket), MAF, AC Delco electrical parts IE: dist, CKP (crankshaft position sensor) usually doesn't go out unless it gets hit by the crankshaft & that = bigger issues like bearings. You can see if it's been impacted by the witness marks on the face of it when you remove it.
Old Sep 4, 2012 | 01:52 AM
50lb_cat's Avatar
+1, I would start with the MAF
Old Sep 4, 2012 | 04:39 PM
rjhvetter's Avatar
Cool
Just wanted to add email to make sure i got info thanks for your input
