HELP-Belt keeps slipping off crank pulley
Old Nov 28, 2008 | 09:00 PM
Sams95's Avatar
Sams95 is an unknown quantity at this point
Default HELP-Belt keeps slipping off crank pulley
Hello and thanks in advance for your help. I have new belt that keeps working off the crank pulley towards the motor. I'm sure I am getting everything lined up right yet it still moves back and over the rear edge each time it's started. Already tore up one belt and would like to correct this.
Can anyone help???!!!
Motor is a 95 4.3 Vortec with air
Thanks
Old Nov 28, 2008 | 09:09 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: HELP-Belt keeps slipping off crank pulley
First make sure that the pulleys all look good and check the tensioner. Also make sure that belt is the correct length ie no reduction pulleys in use on your truck. If the belt is correct I would say that there is a very good chance that the tensioner isnt applying enough tension to keep it on.
bigdaddykane93
Jan 11, 2014 03:40 PM
ChevySkeptic
Apr 15, 2012 06:36 PM
warthogdriver
Lifting Tech
Mar 20, 2012 08:42 PM
luvmychevy
Jun 8, 2011 11:46 AM
Swain
Sep 7, 2007 12:11 PM
