Help....blown head gasket or blown intake gasket..?
Ok guy's I just replaced my fuel pump in my 2001 limited edition trail blazer 4.3 which went well but after getting the truck running I put it in gear to drive and it shook a little then cut off then I noticed it had ran hot in a matter of minutes. I popped the hood and checked my water and anti freeze and it was dry...My friend checked my oil and it looked like coffee with heavy cream! My friend think's I have a blown gasket some where but I can't really afford to get it fixed. My question is can I use a gasket sealer to fix the problem and if so which one is best to use?
One caution, if you drive it like that you will destroy the bearings in the engine. You must change the oil if it is milky.
00 chevy blazer 4.3 vortex. So my truck overheated and blow out my top hose and cracked my radiator.. I changed the spark plugs and radiator. Aswell as oil change. 1 spark plug had gunk. It's still a heavy smog grayish white coming out. Idk if heads are worpped. Should I do an intake or head gasket replacement..it's not leaking coolant.it doesn't turn off not shaky engine.i have less than a hundred and I have the tools as well as the Hayne book.feel confident to make it happen.. need of feed back..
Good chance you have a blown lower intake gasket too if you overheated and have smoke when running. It's likely leaking coolant into the combustion chamber. It's a long job to change it, but it's certainly doable yourself, but plan on it taking at least all day, if not more.
Be sure to get the better quality felpro gaskets. Well worth the higher cost.
Josh Smith
Sep 11, 2015 12:44 PM
badcarma02
Nov 20, 2012 09:20 PM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
