Help - Broken shift stud 4L80e
Old Jul 24, 2011 | 10:38 PM
hivolts's Avatar
hivolts is on a distinguished road
Default Help - Broken shift stud 4L80e
In swapping out a 4L80e, I had to change the shift bracket mounted on the transmission. There is a single nut that holds the bracket to a stud that connects inside the tranmission. The stud broke off when I tried to remove it. Any ideas on how to change the stud? It has a nut on the other end but the stud goes deeper into the tranny. Thanks.
Old Jul 25, 2011 | 07:28 AM
abig84's Avatar
is there any of it still sticking out? is possible to weld a new end on it just to get by?
Old Jul 25, 2011 | 09:17 PM
Any welding on the shift shaft will destroy the lip seal that keeps dirt out & tranny fluid in.
THIS SCHEMATIC shows the shaft. It is held in place by a retaining ring. I believe that this retaining ring is on the inside of the pan and should be readily visible with the pan off. Once the pan is removed, you should be able to pull off the nut on the shift detent comb & then remove the retainer. From there, the shift shaft should be able to be removed.
XxIRISH63xX
Jan 25, 2011 08:29 AM
DREW
Feb 1, 2010 11:45 AM
dennis65gt
Nov 9, 2009 06:25 PM
kiwiblazer
Dec 24, 2008 12:39 AM
Blasir
Oct 7, 2006 03:42 PM
