help! engine chokes out when accelerating
Old Apr 8, 2014 | 10:10 PM
hoebob69's Avatar
hoebob69 is on a distinguished road
Default help! engine chokes out when accelerating
My blazer has sat over a year with me cranking it every couple of weeks. It sat for a little over a month and I had trouble with the idling. Basically it would fire off and slowly choke out. I dropped the tank and got all the old gas out,cleaned the screen, put a couple of gallons premium with a quarter bottle complete fuel system cleaner in with it. I drove it today and it spit and sputtered the entire 10 miles, but only choked out twice. It seems to want to choke out when I give it gas,or when it changes gears. When I got it home it was idling better but still a little off. What is causing this? What do I need to do to smooth it out? I'm stumped on this and any advice would be greatly appreciated!
Old Apr 9, 2014 | 11:21 PM
cleburne red's Avatar
Did you change the fuel filter? That would cause it to stall out under load.
Any check engine lights? I've had bad map sensors cause a vehicle to stall under load, also.
Old Apr 10, 2014 | 05:24 AM
hoebob69's Avatar
Yes I changed filter,dropped the tank and got bad gas out. Cleaned the screen and ran sea foam through it. I just changed the plugs and I'm getting the plugs today. I'll check the map sensor out though. Thanks
Old Apr 14, 2014 | 12:11 AM
Lancealot's Avatar
Lancealot is on a distinguished road
Mouse nest in air filter?
racsan
Dec 9, 2010 09:31 AM
Awesome
Nov 6, 2009 04:33 PM
Denominator
Oct 18, 2009 01:55 PM
Mammon
Jun 30, 2009 02:35 PM
JustBlaze!
Jan 16, 2008 05:00 PM
