Help identifying part underneath car
Old Mar 13, 2018 | 09:52 PM
Blazer199's Avatar
Blazer199 is on a distinguished road
Default Help identifying part underneath car
My 1996 blazer 4wd has and oil leak that only happens when it’s running and I know where it’s coming from but I don’t know the name of the part. It is directly above the knuckle in the 4wd drive shaft and it has the number 10172762 on it and also CAV 10 on it. In appearance it has two line coming off it. Any help at all would be appreciated, thanks.
Old Mar 13, 2018 | 10:40 PM
GreenBlazer2002's Avatar
Can you post a picture of it? That would help us help you much better.
Old Mar 13, 2018 | 10:42 PM
rockp2's Avatar
I believe you are referring to the Oil Filter Pipe Adapter.
Old Mar 13, 2018 | 10:44 PM
Sounds like it is part of the remote oil cooler and remote oil filter system.
These hoses and the fittings are known leaks.
BTW, welcome to the forum.
Old Mar 14, 2018 | 06:48 AM
Check out THIS EXPLODED VIEW schematic from the WholeSaleGMPartsOnline website. As Christine stated, it sounds like you have an issue with one or more of the seals in the oil filter adapter on the block.
macbeth765
Sep 7, 2012 02:10 PM
athens
Sep 21, 2010 03:20 PM
neoalphaflight
Mar 18, 2010 08:08 PM
nezoic
Nov 5, 2009 05:51 PM
punxweb
Sep 18, 2008 12:19 PM
