HELP! Jumping RPM's while driving.
Old Jun 15, 2014 | 08:29 AM
IHartnett85's Avatar
IHartnett85 is on a distinguished road
Exclamation HELP! Jumping RPM's while driving.
Need some help. I have a 2002 Chevy Blazer V6. While driving around 45mph the RPM's begin to jump causing the truck to lurch forward then drop back. If I speed up or drop below 45mph the issue stops. One person I had talked to suggested it being the fuel injector (of which is the 'spider' fuel injector system) but I get no check engine light. Does anyone have any suggestions or ideas what could be causing this issue? Also, I get horrible MPG.
Old Jun 15, 2014 | 10:06 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
does it only do it in overdrive or in normal drive as well? I'm thinking might be a tranny issue? sounds like an issue shifting maybe a belt or solinoid on the tranny?
Old Jun 17, 2014 | 05:09 PM
TZFBird's Avatar
TZFBird is on a distinguished road
Double and triple check the transmission fluid level. The down/up shifting happens when it gets about a quart low.
Old Jul 5, 2014 | 01:53 PM
filtalr's Avatar
filtalr is an unknown quantity at this point
Mine is doing basically the same thing - only it's been rebuilt and the shop just serviced it last week to try to fix the issue ... so don't think the fluid would be low?
Old Aug 6, 2014 | 06:32 PM
s20theforce's Avatar
s20theforce is on a distinguished road
Same problem on my 04 blazer any ideas
Old Aug 11, 2014 | 12:19 PM
burned's Avatar
burned is on a distinguished road
You guys got any codes?
A crank sensor can cause that symptom.
Old Aug 13, 2014 | 07:59 AM
TZFBird's Avatar
I'll also add that you might want to look into the O2 sensor(they don't always throw codes). If it's not reading correctly then it will throw off the AFR and the tug of war between the TPS and MAP sensors will mess with shifting.
Just another path to look into.
Old Aug 14, 2014 | 04:25 PM
I have no codes coming up when I hook up my reader. It only happens in OD. Idle is perfect and shifting is smooth it is just when the trans gets to OD that this issues occurs.
dgraham30
Sep 19, 2010 12:17 PM
creeder_87
Feb 13, 2010 01:12 PM
determan
Jun 18, 2009 07:00 PM
stevelknievel
Jan 18, 2008 09:56 PM
dashyman
Aug 29, 2006 01:05 AM
