HELP my 03 blazer wil not start
Old Dec 9, 2012 | 11:15 AM
debdoodle's Avatar
debdoodle is on a distinguished road
Default HELP my 03 blazer wil not start
ok here we go i have a 2003 blazer 4.3L engine turns over and it will not start so i checked the spark( good) checked the timing( good) hooked up a scanner(no codes) checked fuel pressure (64)when pump comes on when pump turns off it drops to (57) and holds this morning did a compression test they all run between 135 and 150 psi when i removed the compression hose from the plug holes i had gas on the tester.could it be mass air sen,any of your ideas would be great.thanks
Old Dec 9, 2012 | 07:21 PM
Wisco Blazer's Avatar
Wisco Blazer will become famous soon enough
Unplug ur MAF and find out!
Old Dec 9, 2012 | 07:35 PM
50lb_cat's Avatar
How long did you let it sit with the fuel pressure gauge on? It should not go below 55 for 10 minutes. When was the last time it had a tune up? Are all of the lights coming on with the key in?
Old Dec 10, 2012 | 09:10 AM
debdoodle's Avatar
all the dash lights come on it was tuned up about nine months ago plugs,wires,cap new fuel filter when i did the compression test put the plugs back in the wires had spark to all the plugs
jkyle187
Apr 6, 2015 12:58 PM
stschuyler25
Nov 21, 2010 09:34 AM
JPate
Apr 8, 2010 10:39 PM
Radar0066
Tires and Wheels
Jan 9, 2010 04:34 PM
Spazz
Tires and Wheels
Jan 15, 2007 08:25 PM
