99 ZR2 wil not start
Old Apr 3, 2010 | 06:23 PM
JPate's Avatar
JPate is on a distinguished road
Default 99 ZR2 wil not start
Replaced the fuel pump, Filter. Motor is getting fuel but have no gauged it. Motor cranks and almost fire after a couple times of trying. Pulled plugs and cleaned just in case if fouled them. Relay is good. Just can not figure it out.
Old Apr 4, 2010 | 07:27 PM
JPate's Avatar
Geee Thanks for the help people. But I got it.
Old Apr 4, 2010 | 09:20 PM
old skool luvr's Avatar
relax brother, not every post gets seen/answered right away.
i've waited more than a day for an answer.
glad to see you figured it out. why don't you share to fix with the rest of us, might save a fellow member the same in the future.
Old Apr 5, 2010 | 07:22 AM
JPate's Avatar
Sorry for the attitude. Just frustrated with my truck. I have dumped a lot of money into it that I really do not have at this time.
Well the FP went out so I dropped the tank and cleaned the tank up and replaced with a brand new FP. Get it all back in and filled back up with fuel and primed the pump and lines and then tried to start it and it almost fires. Called a friend and we tried starter fluid and it fires up and dies. So we now knew it a fuel issue, So we checked the pressure and nothing registers on the gauge. So we checked all fuses and relays. All good. So I dropped the tank again and check the power to the pump. Power at the wire harness. So the New pump is junk. Then to top it off while trying to get the connector off I snapped the Front fuel port on the fuel pump. So I hope the auto store will let me return it. If not I just lost $250.00 on that pump and will have have to buy another.
Old Apr 5, 2010 | 08:35 PM
now we can understand why you're frustrated & pissed off.
i'm sure the part store would be willing to exchange it. i just hope you bought a good Delco pump, most of the aftermarket one's seem to be garbage. just going by what i've read on here regarding other member's FP issues.
keep us updated when you get it fixed-for good-this time.
Old Apr 7, 2010 | 08:30 PM
Blazinbeatz's Avatar
Blazinbeatz is on a distinguished road
Default Did you fix it
Hello, I just had this similar problem happen yesterday. I was driving for 5 minutes, got on the freeway, then all Of a sudden car dies on me.
So what was your fix? I can still hear my fuel pump turn on, I
have gas and a new battery. The car tries
to start when I hold the key on. One thing I do notice is a lot of play in my distributor.
Old Apr 7, 2010 | 11:22 PM
say what? care to explain a little further.
Old Apr 8, 2010 | 10:39 PM
JPate's Avatar
Got the new pump. So I decied to hook it up before I put into the tank and had my boy tun the key on and nothing. So I got the tester out and now no power to the pump so I must have a wire grounding out some where. I am do working on it. It's going to the shop and after it is fix I am going to sell it
jkyle187
Apr 6, 2015 12:58 PM
debdoodle
Dec 10, 2012 09:10 AM
dubaholic2
May 24, 2011 12:44 PM
Radar0066
Tires and Wheels
Jan 9, 2010 04:34 PM
Spazz
Tires and Wheels
Jan 15, 2007 08:25 PM
