help no spark
Old Dec 25, 2011 | 08:38 PM
reamracing#08's Avatar
reamracing#08 is on a distinguished road
Default help no spark
98 s10 blazer no spark? was driving down the highway and it stalled lost spark
but recently the mileage on the dash dropped 30,000 miles but a week later came back? so maybe a computer problem?
changed the pick up coil,coil test good,ignition module good,changed the crank sensor....no spark still.. any ideas??? power at the pink wire but noticed no flash on white/black all fuses are good.. cap/rotor look a lil dirty so i guess i will change those too (i read the sticky for no spark but im still at a loss)
Old Dec 26, 2011 | 09:19 AM
anyone?
Old Dec 26, 2011 | 09:43 AM
blazer0713's Avatar
blazer0713 is on a distinguished road
i would try if you have a buddy with the same or close to blazer pull his ecu out and try it to rule that out
Old Dec 26, 2011 | 10:03 AM
dont know of another but can get one from a local junkyard and give it a try
also forgot to mention after i replaced the crank sensor and hooked the battery back up the speedo and tach maxed out but later came down on there own
Last edited by swartlkk; Dec 26, 2011 at 12:10 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 26, 2011 | 10:43 PM
update..............
ok new computer in got power had spark but lost it now all signs point to coil no spark from coil now but pink wire is hot white/black is flickers ground
Old Dec 26, 2011 | 10:49 PM
xgiovannix12's Avatar
Old Dec 26, 2011 | 11:02 PM
yep ive went threw those already and i did have the ignition mod checked came back ok only thing not checked is coil so.........
(i also went threw the search option thanks tho)
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
yzf125
Nov 3, 2005 12:55 AM
