Help! Oil pan
Old Sep 12, 2012 | 11:00 AM
Blazer925's Avatar
Blazer925 is on a distinguished road
Default Help! Oil pan
Hi everybody long time lurker new user here love this forum! Anyway just bought a 1996 4wd 4 door blazer a few months ago and have been fixing all the wrong in it had oil leaks thought I got it when I replaced my intake gasket and oil cooler lines but nope more oil leaks narrowed it down to the rear main seal and oil Pan gasket how hard are these to replace myself or should I just let a shop do it? Thanks in advance!!
Old Sep 12, 2012 | 08:20 PM
alpinesubs's Avatar
alpinesubs is on a distinguished road
This is definitely not what you wanted to hear but the engine will need to be pulled for both of them. TO replace the rear main alone the transmission would have to be pulled. If there not gushing I would just keep driving and check the oil level at every stop.
Old Sep 13, 2012 | 09:59 AM
Blazer925's Avatar
Thats defiantly not what i wanted to hear lol. When i check it in the morning i have a spot of oil on my driveway about 4-5 inches across would that be considered "gushing" ?
Old Sep 14, 2012 | 09:29 PM
georgew8714's Avatar
georgew8714 is on a distinguished road
4 to 5 inch spot is a little tough to figure , how many miles do you get before your a quart down might be a better question to answer. I changed out the oil pan with the engine in the truck but the front axle had to be unbolted and moved forward after the center link was removed . Also the motor mounts had to be unbolted and the engine lifted as much as you can without breaking the distributor. As for the rear main seal , Alpinesubs is right you either have to pull the engine or drop the transmission.
Bluebeastblazer57
Aug 11, 2012 11:05 PM
DT727
Dec 25, 2011 09:19 PM
blazin94tahoe
Feb 13, 2011 04:07 PM
mattnew4
Dec 19, 2010 05:47 PM
daniel010
Jan 19, 2009 07:19 AM
