help!!please!!!
Old Jul 15, 2008 | 01:46 AM
gr8y8's Avatar
gr8y8 is an unknown quantity at this point
Default help!!please!!!
i purchsed a 2001 s10 4x4 blazer with a 4.3ltr engine with 98,000 miles i now notice a "shutter" when the truck is warm (in closed loop) mostly when turned left or right doesnt matter if in drive or reverse. sometimes feel the shutter in drive on accleration. it only does this after the truck is warmed up, when its cold it runs great. the truck has had a recent tune-up ,the engine runs fine no miss, no smoke, on the hiway runs good,only engine code is apo410 an A.I.R pump not working. any help would be greatly appriciated!!!!
Old Jul 15, 2008 | 09:17 AM
Default RE: help!!please!!!
Old Jul 18, 2008 | 04:13 AM
gr8y8's Avatar
thanx for the reply yes it does all this shutteringmostly, when the steering wheel is turned does not matter if going foward or backwards power steering fluid dark i added very little to bring it up to correct level. so what are you thinking? any help would be great!
Old Jul 29, 2008 | 05:57 AM
blazerguy89's Avatar
blazerguy89 is an unknown quantity at this point
i would try a fluid change (flush) first and go from there.
Old Jul 29, 2008 | 07:49 PM
Hanr3's Avatar
um, I would fix the air pump first.
tranny performance is based on engine performance, tehy work as a team.
opposedforces
Sep 1, 2011 02:59 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
blazin4eva
Feb 26, 2005 12:04 PM
blazin4eva
Jan 27, 2005 02:02 PM
