HELP!starter grinding!!
Old Mar 29, 2010 | 12:57 PM
B-Lazer's Avatar
B-Lazer is on a distinguished road
Default HELP!starter grinding!!
have a 84 chevy k5 blazer that previously had an aftermarket starter that grinded no matter how many shims i used,i replaced it with a stock starter and for about a week it didnt grind at all,then it started to grind so i put a .40 shim in it and it was fine for about a day then it started grinding,so i took the shim out and it is fine again????i am mechanically inclined but i dont understand why its doing this,the flywheel is in ok condition,not bad enough to cause problems..Ideas?
Old Mar 29, 2010 | 01:05 PM
Are the bolts staying tight? Can the starter move at all side to side (twist)? How did you determine that you should use 0.040" shims (I assume you left off the first zero because 0.4" is A LOT).
Old Mar 29, 2010 | 01:16 PM
B-Lazer's Avatar
yeah its 0.040 and no i doesnt move at all,i dont understand it at all,and i dont have time to keep shimming and un-shimming my starter either which is weird,and i determined i used 0.040 because thats what it says on the shims i purchased and im assuming thats the thickness.
Old Mar 29, 2010 | 01:23 PM
Have you rotated the flex plate around and inspected the gears all the way around? As well as checked the clearance all the way around? It is possible that there are some really damaged gears and/or that the flex plate is bent opening up or closing up the clearances depending on where the engine stops.
Old Mar 29, 2010 | 01:31 PM
B-Lazer's Avatar
it could possibly be bent but that wouldnt explain why for a week with a brand new starter it was fine and then i shim it and its fine for awhile and when i take the shim out its fine again..because once it starts grinding again,it doesnt stop it will grind every time i turn the key untill i fix it.
Old Mar 29, 2010 | 01:38 PM
Luck of the draw? I had a 3" section of teeth out on the flex plate in my Chevelle. It went fine for a long while before it hit that section and the starter just spun. That car started up without going through 1 revolution of the crankshaft as I suspect yours probably is as well.
Old Mar 29, 2010 | 01:41 PM
B-Lazer's Avatar
every time i shim and un-shim the starter i have looked at the flywheel and i have seen no bad sections,and unless my truck is warm it takes about 10 seconds of cranking before it starts,and usually it grinds real bad for about 5 of those seconds then it will get a little better.
Old Mar 29, 2010 | 02:03 PM
Something isn't right in there. No use speculating until you have verified that the flywheel is straight, round, and has all its teeth.
Jason10476
Sep 27, 2021 10:27 PM
jdmmario
Oct 25, 2014 06:25 PM
donniejo32
Mar 14, 2013 11:28 PM
Funkypantsman
Apr 2, 2011 05:42 PM
offskooring
Jul 31, 2009 07:59 PM
