HELP!!! Still having missfires!
I have a 95 Blazer with a 4.3L engine. I have replaced the plugs, wires, cap, rotor, fuel filter, fuel pressure regulator (it was leaking), and the plugs again after the regulator. It still has a miss, and needs to be smoged ASAP. Any help would be greatly appreciated. Thanks.
Finaly got the check engine light to go off, I replaced some more vaccum lines. It had a bad vaccume line to the charcole canister. Drove it around got it smogged and found out that the HC at idle were too high.Any body have any Ideas on what to do? its the only thing that made it fail.
http://www.smogtips.com/failed-high-hydrocarbons-HC.cfm
This link should help explain what's going on.
Northern Z7
Jun 16, 2014 07:09 PM
RolingKCBlazer
Oct 11, 2008 05:11 PM
Unlimitedsp
15
Feb 4, 2008 04:44 PM
vmx120
Sep 12, 2005 07:10 PM
