HELP!!! Still having missfires!
Old Aug 3, 2012 | 12:12 PM
bearblazer's Avatar
bearblazer is on a distinguished road
Default HELP!!! Still having missfires!
I have a 95 Blazer with a 4.3L engine. I have replaced the plugs, wires, cap, rotor, fuel filter, fuel pressure regulator (it was leaking), and the plugs again after the regulator. It still has a miss, and needs to be smoged ASAP. Any help would be greatly appreciated. Thanks.
Old Aug 3, 2012 | 12:16 PM
50lb_cat's Avatar
Is it a random misfire or on a specific cylinder? What brand did you use for the tune up?
Old Aug 3, 2012 | 04:00 PM
bearblazer's Avatar
It was a P0304 and now its just a random missfire. I used AC Delco parts, and all the plug wires are on properly.
Old Aug 3, 2012 | 09:06 PM
bearblazer's Avatar
Im hoping the CEL will stay off long enough to get it smoged, but if it comes back on I will be replacing the coil to see if that helps. Come on guys anything helps.
Old Aug 17, 2012 | 07:12 PM
bearblazer's Avatar
Finaly got the check engine light to go off, I replaced some more vaccum lines. It had a bad vaccume line to the charcole canister. Drove it around got it smogged and found out that the HC at idle were too high.Any body have any Ideas on what to do? its the only thing that made it fail.
Old Aug 18, 2012 | 01:23 AM
50lb_cat's Avatar
http://www.smogtips.com/failed-high-hydrocarbons-HC.cfm
This link should help explain what's going on.
Northern Z7
Jun 16, 2014 07:09 PM
94BlazerPA
Jul 8, 2010 09:34 PM
RolingKCBlazer
Oct 11, 2008 05:11 PM
Unlimitedsp
15
Feb 4, 2008 04:44 PM
vmx120
Sep 12, 2005 07:10 PM
