help transmission problems
Old Apr 23, 2014 | 01:29 PM
supermario28's Avatar
supermario28 is on a distinguished road
Default help transmission problems
I have a 95 Blazer 4WD 4.3. My problem is that when I step on the Gas I hear the high revving, not from the engin but from the transmission. I put two quarts of tranny fluid it stoped and after like three weeks its doing it again. there's no leak so confussed on whats going on.
Old Apr 23, 2014 | 02:13 PM
sputtle's Avatar
sputtle is on a distinguished road
Get a transmission flush asap first. But sounds like that's only a bandaid for a bigger problem
Old Apr 23, 2014 | 02:50 PM
It shifts good either way it just shift a little higher on the rpm before I add the tranny fluid
Old Apr 26, 2014 | 01:01 PM
sputtle's Avatar
I had a whole reply all typed out but after reading your first post, I'm not exactly sure what's going wrong. Is your transmission struggling to shift into gears? Does the 4x4 HI and LO still work properly? Are you sure you're not being overly critical of the transmission operation? A little more detail will help.
Jakeduece
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Sep 19, 2013 07:00 PM
Texasrebel70
Apr 10, 2013 01:54 AM
mav06
Jun 13, 2009 07:38 PM
upblazer95
Apr 4, 2009 08:27 PM
chris24301
Jan 24, 2007 11:01 AM
