cutting off
Old Apr 26, 2014 | 06:25 PM
93blazin's Avatar
93blazin is on a distinguished road
Default cutting off
i have a 93 s10 blazer it is fuel injected. after driving for about 30-45 mins it will cut of just like you turned of the switch. the first time it did this i call to get it towed. after sitting for about an hour it started up and i drove it onto
the trailer. any ideas
Old Apr 26, 2014 | 07:49 PM
richphotos's Avatar
I would check the fuel pressure and leak down.
KOEO (Key on Engine off) the pressure should be 60-62psi and should not drop below 55psi in 10 minutes.
Post back with the results.
Old Apr 26, 2014 | 09:59 PM
chris015's Avatar
either pump,spider or coil...
im thinking towards coil....when they heat up..its a turn key off like issue. If its not that,,,your screwed into pump or spider.
pump is 60 bucks (ac delco via rockauto,go anything else you WILL have issues)
spider 135 after shipping. its under the manifold. they are bad for leaking...
do a fuel pressure test like rich said....one at the engine...if reads below 58,check at pump. if pump hits 60+ pumps good. pressure drops at the manifold,spiders bad.
gmoney30
Oct 25, 2010 07:42 PM
Msmaia
Nov 10, 2009 02:56 PM
xtreme01blzr
Oct 18, 2006 03:23 AM
KA3AX
14
May 12, 2006 05:07 PM
blazerscooby
Mar 19, 2006 02:52 AM
