Hesitates, bucks and backfires under load
Old Feb 19, 2015 | 05:35 PM
jacksung's Avatar
jacksung is on a distinguished road
Default Hesitates, bucks and backfires under load
2000 Blazer V6 122,000 miles. Turn the key and starts quickly every time and idles smooth. In park if I push on gas slow the tach will go all the way up. In park if I push on gas quickly it will hesitate, buck and backfire at about 3000, if I let off the gas some it will stop cutting out. I would take to a garage but it does not have enough power for the hills I must drive. It left me stuck on a hill already. I have changed plugs, cap and rotor. Tbs checked out ok. Put sea foam in but still have not been able to get fuel filter off for replacement but I will. Have not done fuel pressure test because I don’t have a gage and don’t think I can drive to get one, but if I must I must. It does not put out any codes.Appreciate any ideas.
Old Feb 20, 2015 | 07:58 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
Got to get the fuel pressure checked first and foremost if it's not throwing any codes. can't do much else till we see whats happening with the fuel system.
Old Feb 20, 2015 | 10:15 PM
jacksung's Avatar
Thanks for the come back. Did a pressure test at service port. 60 pounds leak down at 55 after 20 minutes. Tested Coil, TPS, new air filter and new Plugs( lots of fun). Still same problem. Thanks again
Old Feb 22, 2015 | 01:57 PM
Gregg64's Avatar
Ok ,next you should do the Max Outlet Pressure test on the fuel pump. You do this at the outlet port of the fuel filter. It should show 73 too 108 PSI and have very little leak down. If it does have leak down then either the return check valve is bad or the pump is not able to provide constant consistent fuel pressure to the engine and a good regulator will not show this problem.
Old Feb 23, 2015 | 02:26 PM
pappy57's Avatar
pappy57 is on a distinguished road
im having similar problem with my 2000 blazer backfireing into trottlebody but only does it for a few min affter a few min it piucs up and runs fine untill i stop and let idle for a few min then it starts choffing all over again what the hell is going on still not throwing any codes eigther
Old Feb 23, 2015 | 02:28 PM
pappy57's Avatar
new plugs plug wires cap and rotor new fuel pump new dist. new crank sensor new fuel reg
Old Feb 24, 2015 | 06:11 PM
Gregg64's Avatar
Pappy you will need to do the Crank sensor re-learn on yours since it was replaced. this will cause issues if not done correctly and must be done on a scanner that can perform the task. Cheap scanners cannot do it.
Old Mar 2, 2015 | 07:13 AM
pappy57's Avatar
so any suggestions where to go
Old Mar 10, 2015 | 06:58 AM
pappy57's Avatar
i had don brown chevy do the relearn now my problem is the shock on passenger side came loose and jumped up and cut 5 wires i repaired wire and had to replace two o2 sensors now my problem is it starts perfect but doesn't want to move acts like and old carb with an accelerator pump problem untill it desisdes to move a couple of min after you try to take off then it runs perfect untill next time i turn te key off
any ideas
Ryan Cornforth
16
Feb 19, 2013 01:55 PM
flatearthling
Aug 3, 2011 07:24 AM
drew_fur
Jun 9, 2011 11:46 AM
loblzr
Lowering Tech
Mar 13, 2011 08:27 PM
oopackmanoo
Sep 27, 2010 09:33 AM
