High Idle, and Misfire Questions
Old Nov 12, 2013 | 03:06 PM
blake6dirt's Avatar
blake6dirt is on a distinguished road
Default High Idle, and Misfire Questions
I have a 1995 chevy blazer 4wd...I was having troubles with it running and starting I couldent figure it out so I tore it down...it now has rebuilt heads, rebuilt upper and lower intake manifolds, new head, exhaust, and intake gaskets, new spider injectors, fuel hose repair kit, and fuel filter. A new distributer, cap and rotor, plugs and wires, oil pressure switch, coolant temp sensor, air filter, deleted the egr and a few other things...it now starts awesome but has a miss and a very high idle that dident happen until I drove it a few miles...I currently have the vacuum system tore apart looking for leaks, and im dead in the water I cannot figure out what my problem is and neither can anyone I have talked to....has anyone had this similar problem?
Old Nov 12, 2013 | 03:19 PM
blake6dirt's Avatar
I was told to check out my IAC
Old Nov 13, 2013 | 11:28 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Check your TPS. I have an intermitent poor connection between the TPS and the harness connector. Not sure what to do about it just yet but at least I know what the problem is. Sounds just like your issue. Stick with the troubleshooting and the answer will eventually turn up.
Old Nov 13, 2013 | 12:04 PM
chris015's Avatar
post actual fuel pressure results at key on,and pressure after its set for 10 min.
mcdevin1973
Oct 5, 2014 02:52 PM
rrk03300
Nov 15, 2012 10:29 PM
pappyam
Dec 5, 2010 08:25 AM
nonblazing4x4
18
Dec 28, 2008 02:02 PM
tbrincefield
Apr 15, 2008 09:29 PM
