High milage 4.3
Old Mar 12, 2008 | 05:11 PM
ron768's Avatar
ron768 is an unknown quantity at this point
Default High milage 4.3
Not in the blazer, but in an S-10 pick-up. The 91 S-10 Imm driving now has 206,000. miles on it. The oil pressure gauge is showing low oil pressure, 10-20 psi when cold. When hot 5-10 psi. With this milage should I replace the oil pump? Also, should the timing gears and chain be replaced at this time. This engine is tight, no oil leaks, dosent burn any oil between changes.
Old Mar 12, 2008 | 09:44 PM
Verno's Avatar
Verno will become famous soon enough
Default RE: High milage 4.3
If it's not dripping, or burning oil, an still running good, I don't know if I'd be alarmed about the gauge.
I'm not sure they need lots of pressure anyway, but the pump sounds like the right move.
I've got a 92 S-10 4.3 with 186k, Cold it's pegged, Hot it's 20 @ idle, then gas it and it pegs it again.
When I had it tuned last, the service guy told me it only had 4 degree slop in the timing chain, said not to worry about just yet.
It don't burn any either, but I sure hope it makes it to 206k, lol.
Good Luck.
Old Mar 13, 2008 | 05:53 PM
Hanr3's Avatar
If it were my truck, I would replace teh oil pressure switch first. After 209,000 miles there is bound to be some sludge built up on the sensor. Besides the replacing the oil pump is not quick and if you have a 4x4 requires either lifting the engine or removing teh front driveshaft.
Old Mar 14, 2008 | 01:52 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
It should have 8-10 psi for every 1000 rpms
Old Mar 14, 2008 | 06:42 AM
rriddle3's Avatar
I would consider your pressure to be at the bottom of the acceptable idle range. Have a mechanic (or yourself) hook a mechanical gauge to the pressure sending port and see if the readings you have are due to the factorysending unitor the pump itself.
Old Mar 14, 2008 | 11:53 PM
4x4blazerguy's Avatar
I would add a quart of Lucas at every oil change & run it. Run like 20-50 wt oils or a 50 weight racing oil. 4.3 is a 350 with 2 cylinders dropped, I have seen small block chevy run with little pressure, when the lifters start to make noise on a regular basis then it is time to replace. I doubt an oil pump will do much with that mileage. I have a Lumina with a 3.1 V6 with 236,000 miles on it. All it has are idiot lights thank God. But it runs great.
Old Mar 15, 2008 | 01:39 PM
Verno's Avatar
ORIGINAL: Verno
I've got a 92 S-10 4.3 with 186k, I sure hope it makes it to 206k, lol.
Dang, fuel pump went out this morning.[sm=smiley19.gif]
WolfPack
Jan 15, 2008 04:54 PM
tammikm
14
Jan 28, 2007 02:39 AM
getbent
Nov 21, 2006 04:33 AM
tommyd
Oct 25, 2006 01:10 AM
magnum434
Engine & Internal
13
Aug 17, 2006 01:44 AM
