HM290 Bellhousing bolts...
Old Jan 29, 2021 | 02:44 AM
BlazerDog97S10's Avatar
Default HM290 Bellhousing bolts...
Howdy...
Anyone know where I can get new bolts for the bellhousing on an HM290 in a base model 1997 Blazer 2door 4x4? I tried most GM parts places and Ebay and Amazon and local parts places and I can't find any help. Don't want to get them from a junk yard, Want new ones. Figured I could just go to Ace Hardware or Home Depot and get some bolts that match, but pretty sure the bolts need to be a certain tempered grade to be mounted on the motor.
Help would be MIGHTY appreciated!
Old Jan 29, 2021 | 08:51 AM
Transman304's Avatar
The Bolt Barn on eBay will have what you need. Flange head, 10mm x 1.25 thread, 10.9 grade JIS in the lengths needed. Do you have the old bolts to measure?
Brad
Old Jan 29, 2021 | 11:12 AM
Brad
Obliged for directing me in the right direction. I don't recall the lengths but I can find out. I think they were 1.5 or 1.75" in length maybe 2". I'll get under after work and post reply.
Old Jan 29, 2021 | 09:28 PM
Bolts I need are 1 5/8" in length, so I reckon I could find something in that.
Old Jan 30, 2021 | 05:00 AM
I listed incorrect pitch size of threads in first post. What you will be looking for is M10 x 1.50 x 45mm.
Good luck
Brad.
quick search on amazon showed these.
Old Jan 30, 2021 | 06:10 PM
Good luck
Brad.
I already ordered the other ones on Ebay. I'll order some of these as well. Obliged for the help.
Old Jan 31, 2021 | 11:38 AM
Glad you were able to get the bolts.
Good luck
Brad
Old Jan 31, 2021 | 02:07 PM
Good luck
Brad
Obliged. Not meaning to get off topic but noticed yer in WV. I'm looking into getting a house with some folks in Charleston in a few months. Main reason I want my Blazer in perfect condition to drive there from Oregon. I hate this place for numerous reason. Maybe I'll see ya around the roads sometime.
Take care.
Old Feb 6, 2021 | 01:10 AM
Mods's Avatar
Failing that i typically get my hardware from McMaster-Carr, great item and shipping prices but count on ordering in Bulk.
Old Feb 8, 2021 | 08:03 PM
Update...
Got the new bolts but they are not the correct size to mount the bellhousing to the back of the motor. So I went to the Home Depot with the old bolts that fit and they are 3/8"x16 threads. The M10x1.50x45's don't even go into the holes in the back of the motor.
So off to get the correct threaded bolts again. Luckily bolts are expensive, just a slight set-back and annoyance. The incorrect bolts are going in the miscellaneous bolt bin.
