how do you replace the radiator?
Old Jul 3, 2007 | 04:45 PM
spanky's Avatar
spanky is an unknown quantity at this point
Default how do you replace the radiator?
Well the suject is the queston. How do I replace the radiator?
Old Jul 3, 2007 | 04:47 PM
spanky's Avatar
Default RE: how do you replace the radiator?
Oh, I forgot to say its a 1976 chevy blazer. Thanks.
Old Jul 3, 2007 | 06:04 PM
Please use the edit function to add additional information to your post if another member had yet to reply.
On replacing your radiator. Drain the coolant, disconnect the upper and lower radiator hoses, disconnect the transmission cooler lines (if applicable), remove the upper radiator shroud/support, remove the radiator. You'll probably want to replace the upper and lower hoses as well as the thermostat while you've got the system open. This would also be a good time to evaluate the bearings in the waterpump. If they feel lose or like something is grinding inside, Installation of the new radiator is reverse of disassembly. You'll need to check the level of the transmission fluid if you disconnected the lines.
BDS_237
Apr 19, 2010 11:05 PM
bigdaddykane93
Jan 4, 2010 12:03 PM
vermillion2
Jan 8, 2008 01:12 AM
mel
Jan 20, 2006 08:21 AM
kk22696
Nov 28, 2005 03:29 PM
