How far to fully seat torque converter!?
Old Aug 27, 2011 | 12:48 PM
Blazin_Jason's Avatar
You should be able to rotate the tc while pushing back and it should set back 2 obvious times. Just keep spinning and pushing till its home. When it's fully seated, you will be pulling the tc towards the flexplate slightly when you bolt them together.
Old Aug 27, 2011 | 02:24 PM
^^^^^^^^THIS^^^^^^^^
Failure to fully engage the snout into the drive dogs on the pump will result in a cracked pump drive if you try to install it that way.
Old Aug 27, 2011 | 04:40 PM
kgkern01's Avatar
kgkern01 is an unknown quantity at this point
OK, so I went back out there and made sure I lined up the keys on the transmission pump to the slots on the converter, finally got it to go into place with a little wiggling.
Now, the converter doesn't turn when it is fully seated. When it was part of the way in it turned easily, now that it has seated, it doesn't turn. Is this normal or is the pump bad?
Old Aug 27, 2011 | 05:00 PM
It should turn rather freely once it engages into the pump... Can you spin the pump drive with the converter out?
Old Aug 27, 2011 | 05:05 PM
kgkern01's Avatar
How do I spin the pump drive with the converter out?
Old Aug 27, 2011 | 05:21 PM
Two slender screw drivers? You should be able to spin it with just one screw driver, but it has to be fairly long & slender to not damage the seal.
Old Aug 27, 2011 | 05:35 PM
kgkern01's Avatar
Ok, it's seized...awesome. The pump on the old trans turned fine, the 'new' trans one didnt budge. So how hard is it to replace the pump? Any parts stores carry one?
The reason I pulled the old trans was due to the 3-4 clutches going out after a trans line leaked on me on the x-way. I have been driving fine with 1-2 gear since then.
Old Aug 27, 2011 | 05:44 PM
The pump is a tight fit into the front of the transmission. THIS PAGE should shed some light on it (found by doing a google search for "4L60E pump removal") if you don't have the specialized tooling to pull it.
Old Aug 29, 2011 | 07:44 PM
kgkern01's Avatar
Got the pump out, it was actually not too hard to do, didnt have to remove the bellhousing either, although it made it a little snug to get out that way. Local trans shop said they may be able to repair it and if not have some good used/rebuilt ones for about $60. Hopefully everything else with this other trans works ok! Do NOT want to do a trans swap on this truck again!
Old Sep 22, 2011 | 12:02 PM
hardyboy's Avatar
hardyboy is on a distinguished road
Pull it out turn push it in and it will drop farther where it should be I remmber mine made a click when it went into the right spot
killallblue
Oct 27, 2009 02:14 PM
Shaymus
Aug 1, 2007 07:20 PM
blackhole79
Sep 4, 2006 01:40 AM
Canadian88
Feb 13, 2006 04:04 PM
blazerrick
14
Dec 28, 2005 09:07 PM
