How to get a Blazer out of "park"
Old Aug 2, 2021 | 12:50 PM
Fullerton's Avatar
Fullerton is on a distinguished road
Default How to get a Blazer out of "park"
My grandfather had a 1992 Chevy Blazer 2WD with the V8 Vortec engine. His house was ransacked and the thief stole every key in the house, including the Chevy Blazer keys.
We're selling the house and need to move the Blazer ASAP. What options do we have for getting the transmission out of park without a key, so it can be loaded onto a tow truck? The Blazer has been sitting for years and is not operational, with a very dead battery, if that makes a difference.
Old Aug 2, 2021 | 05:56 PM
This is general advice as I'm not familiar with the full-size Blazers.
If the gear-shift linkage could be disconnected from the transmission, then the transmission could be shifted using the linkage or even at the transmission itself effectively bypassing the ignition switch lock.
Good Luck
Old Aug 2, 2021 | 06:13 PM
Fullerton's Avatar
Good Luck
I misspoke in my original post. It's a V6 Vortec on the S10 chassis.
Would the same process apply?
Old Aug 2, 2021 | 06:40 PM
Yes, I believe so. I've never tried though. Try to find a schematic or diagram for the shift arm on the transmission for that vintage S10 Blazer to guide you.
Old Aug 2, 2021 | 09:29 PM
AJBert's Avatar
Or pull the drive shaft. It should roll unless there are problems with the rear diff or front bearings.
Old Aug 23, 2021 | 06:32 PM
SilvrHairDevil's Avatar
SilvrHairDevil is on a distinguished road
If it's not too late to be helpful, when you pry up the rubber shroud at the base of the shifter, there's a white plastic tab the will take it out of Park. At least - that worked on my 97 4x4.
RedValor
Jun 18, 2021 10:27 PM
Squatcher
Dec 27, 2015 10:27 AM
Blake726
Jan 3, 2015 07:00 PM
bigjblaze
Oct 19, 2009 07:11 PM
emf_1978
Jul 20, 2009 10:58 PM
