how to remove inspection cover off of transmission bell housing
Old Jun 1, 2014 | 01:50 PM
kmartin's Avatar
kmartin is an unknown quantity at this point
Default how to remove inspection cover off of transmission bell housing
I have a 2003 Chevy Blazer. This might be a stupid question and addressed already. How do you properly remove and put back on the inspection cover on the transmission bell housing?
Old Jun 3, 2014 | 01:02 PM
abig84's Avatar
i think you have to drop the exhaust. i know on most fullsize trucks they run the exhaust right under it. if its a metal one you can kinda mangle it and pull it through you just have to bend it back once you put it up so it doesnt rub
Old Jun 3, 2014 | 05:23 PM
On the 98+ trucks (and some 97's), the bell housing is separate from the transmission and is a full circle housing.
There is a stamped steel inspection hole cover that can just be pried out with a screwdriver and then put back into place, again using the screwdriver to compress the clips enough to get them back through the hole.
There are also two rubber plugs that can be pulled out using a pair of pliers. Lubricating them with motor oil helps them go back in.
kmartin
Jun 2, 2014 02:07 PM
avelate63
May 20, 2011 12:53 PM
Mjseyler
Jan 5, 2010 12:44 PM
95Blazer4x4
Mar 7, 2008 07:54 PM
hitr0099
Dec 10, 2007 11:23 PM
