I can't fit a Ratchet and I can't move the bolt with wrench
Old Oct 11, 2011 | 07:34 AM
  #21
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
My blazer is OBD1 and it only has one, four wired O2 sensor in the Y-pipe.
Old Oct 12, 2011 | 01:12 PM
  #22
kuojo's Avatar
kuojo is on a distinguished road
I can only find 2 but I keep hearing rumors that there may be a third that has to be replaced as well. I have one on my Y-pipe (already replaced) and another just behind the cat and right before the muffler. I am going to replace the one between the cat and the muffler and see what happens
Old Oct 12, 2011 | 07:26 PM
  #23
Hanr3's Avatar
If you had a third it would be located on the drivers side y-pipe just below the y-pipe to exhaust manifold connection, somewhere around the frame rail.
Old Oct 12, 2011 | 08:00 PM
  #24
pettyfog's Avatar
Try this
Attached Thumbnails I can't fit a Ratchet and I can't move the bolt with wrench-98_o2_sensor.gif
Old Oct 12, 2011 | 08:22 PM
  #25
Fog, that picture is for the 98+ trucks.
A '95 OBD1 setup will only have 1 O2 sensor just after the 'y' in the y-pipe before the catalytic converter called the upstream sensor. The OBD1.5 & OBD2 '95 models will have 2, same location as the OBD1 setup as well as a post cat sensor. NEVER replace a post cat sensor unless it's setting a code and even then, only after properly diagnosing the code to determine if the sensor is actually faulty. Only the upstream sensor has anything to do with fuel management in the engine.
The sensors themselves are identical in every way; the AC Delco # is AFS75.
Old Oct 14, 2011 | 12:01 AM
  #26
kuojo's Avatar
Alright. Guess its time to get the code now and see where the issue is. At least there is only 2 sensors on my truck, thanks guys for telling me. Do you know of any places that can scan an OBD1.5 code off a 16 pin connector?
Cody0103
Performance & Brainstorming
Jan 11, 2014 01:33 PM
bigblazer46
Tires and Wheels
Mar 21, 2010 12:27 PM
dacop
Jan 16, 2010 06:12 PM
myS108a4RE
Feb 27, 2006 11:30 PM
