i need help figuring out whats wrong
first thing i would do is clean the mass air flow sensor.
(square silver looking thing on the air filter hose going to the throttle body).
Take it off,and pick up a can of mass air flow cleaner. Use this ONLY! Spray the inside of the sensor really good and let it dry. reassemble and drive it.
Now,like on mine it goes into overdrive around 52 mph. Once it drops below that you can feel it shift,which is normal. If im cruising around 52 it'll lock in and out of gear until you get away from it.
Id check fluid level after driving it for a while. Make sure its leveled,and you leave it running in park when you check it. If fluid is red,and doesnt smell burnt then just drive it. If its brown,or dirty looking,do a pan service. Not a flush.
i had the fluid changed Dec. 6 and it still does it....between 38 mph or 57mph and u can set it at any of the speed in between and it will do it if your under it or over tht speed it fine...no codes but the abs light is on and the driver hub is bad
red1127
08-01-2014 12:31 PM
jtlockwood88
02-05-2011 07:02 PM
blazerJim1701
01-16-2010 10:19 AM
