Idle Misfire
Old Jun 17, 2020 | 07:06 PM
Mods's Avatar
Default Idle Misfire
Ruling out everything ignition related as its all ACDelco and brand new, plugs, rotor and cap, new set of wires, all replaced as part of general maintenance recently. went straight to check fuel trims, Long trims are about 3.1-3.9 Banks 2 and 1, and then Short trims arc to about 7-8, usually hovering around 5 and dropping to 0-2 when i start laying on the throttle, i believe that indicates a rich running condition but im not sure. and there is a pretty constant stream of some liquid dripping out of the cracks in the exhaust flanges. at about 700-1000 RPM is smoothes out completely and runs/feels like a dream. Where do i start? i know one of the injector hoses was pulled off (cyl 3 injector), its an MPFI system and the injector was stuck in the manifold, hose came right off so im not sure if it could be leaking from in there and flooding out cylinder 3. once its off idle its fine so im really not sure, Fuel trims both long and short stay above +0 the entire time
Old Jun 18, 2020 | 04:01 PM
8baller's Avatar
8baller is on a distinguished road
Default misfire
I had to have my spider changed out all your fuel injectors come hooked all together was driving me crazy here we need inspection which sucks cost me 800 for parts and labor i had just gotten my little blue Mule now i just try to fix it before sending it out,it did fix the problem though look up on youtube not hard
Old Jun 20, 2020 | 04:11 PM
daveca's Avatar
Too lean on idle will do that. Air leaks around the intake manifold are common. There must be sufficient fuel reaching the spark plug gap for the ignition to fire the plug under compression pressure.
Justin56
18
Jul 31, 2017 10:16 AM
RandyRhoadsFan82
Nov 14, 2013 10:52 PM
2tone2g
May 31, 2011 09:37 PM
jeffr_ca
Jul 19, 2010 10:25 AM
tbrincefield
Apr 15, 2008 09:29 PM
