Idles rough with a knock...
Old Nov 20, 2007 | 03:17 AM
  #31
drperry's Avatar
Default RE: Idles rough with a knock...
I think it was just a hold over from running it without it plugged in for the seafoam treatment... as the SES light wasn't on...
I dumped in a bunch of injector cleaner, and it seems to run better/smoother... still a bit of a miss and a knock, but not quite as bad...
Hopefully the fuel filter finishes it off...
Old Nov 22, 2007 | 12:37 PM
  #32
SillyLittleBlazer's Avatar
SillyLittleBlazer is an unknown quantity at this point
How much of a chance is there of fouling the plugs up when using seafoam? I just changed the plugs (ac delco $5.88 a piece) 10,000 miles ago, dont want to fudge them up
Old Nov 22, 2007 | 12:55 PM
  #33
drperry's Avatar
They might be good enough that they'll be unaffected...
If you still have your old plugs, you can always swap them in...
Since the problem has gotten a little bit better, with the injector cleaner, it's pretty much confirmed that it's a spark, or fuel issue...
It doesn't start missing until it hits low idle, once it does, it always misses, until it cools down again... Maybe I should get my battery/alternator tested, lol.
Old Nov 22, 2007 | 01:27 PM
  #34
You shouldn't have any problems with your plugs. If you think that you may, then I would just remove them after you are done and make sure that none of them are fouled.
Old Nov 27, 2007 | 07:29 PM
  #35
drperry's Avatar
Well, I changed my radiator cap today, and topped up my coolant overflow tank...
The radiator was full, though, so I don't think I have to worry about a headgasket...
Old Mar 23, 2008 | 09:32 AM
  #36
drperry's Avatar
I suppose I should've updated this thread... My engine blew a connecting rod
Not bad, I suppose... Since it'd been making this noise for a good 15000km.
PvBill49
Apr 2, 2012 04:36 AM
nhguy261
Dec 30, 2010 01:41 PM
ryanmancl
Jul 2, 2010 04:44 PM
hubert hefner
63
Mar 16, 2010 11:29 PM
91Blazerblk
Sep 25, 2006 03:23 AM
