Igniton timing
Old Mar 10, 2008 | 08:20 PM
Fast89z28's Avatar
Fast89z28 is an unknown quantity at this point
Default Igniton timing
I know this is going to sound stupid but. i have a 98 4.3 CSFI i just changed the motor anyway. i have an issue that is making mevery angry. the timing on the truck is suppose to be -1 or 0 and you are saying to your self thats crap you cant set the time cause its a fixed distributor and the computer does the rest. i set the distrib i tooth forward and one back no run. just backfire sounds like its 180 off not the case. truck runs great but the snap-on scanner and all other say its 12 degrees advanced??? it makes no sense to me unless the cam sensor or crank sensor is f ed up. ever run into an issue like this? cause when you nail it it good intill the high rpms in wich i belive the knock sensor is taking over?? i am lost but i need to get the timing to 0 or -1 where it needs to be please help!
Old Mar 11, 2008 | 07:50 AM
Default RE: Igniton timing
Timing is never straight up... I thought I had an excel spreadsheet in my Google Docs from my last few scans of my Bravada, but you will never see 0 timing on these motors. No motor that I have ever timed was set to zero advance...
Denominator
Sep 23, 2010 02:40 PM
hotrodln
17
Apr 26, 2010 07:32 PM
Denominator
Apr 25, 2010 06:31 PM
mbrjay
Sep 3, 2009 12:53 PM
joweiby
Nov 6, 2007 07:53 AM
