Inconsistent RPM shifting 1-2 4L60E
Old Oct 3, 2016 | 11:35 AM
Kungpaoshizi's Avatar
Kungpaoshizi is on a distinguished road
Default Inconsistent RPM shifting 1-2 4L60E
97 LS blazer 4dr, vin W..
Got it few weeks ago, everything is pretty good, I've replaced a ton since it's 170k miles. Other than a slight shake at idle that affects the side mirrors.. I've been wondering about the transmission.
It seems to happen when cold which makes me wonder about people talking about the 'it will rev higher to warm the engine/trans lube purposely', set by the pcm iirc..
But is this a sign of transmission problems or is it intentional?
I don't seem to have any other shifting issues that I've noticed. Cycling through the gears manually seems to react normal, no delays. (which makes me wonder about the 'warming up' cycle with these?)
Any other info or things to observe would be helpful. Since I'm new to this transmission I've no idea what's what.
Thanks!
Old Oct 3, 2016 | 01:01 PM
newguy's Avatar
motor mounts maybe
Old Oct 11, 2016 | 11:04 AM
Checked em, they're a little worn but not bad...
Old Oct 13, 2016 | 11:05 AM
R@G3D's Avatar
R@G3D is on a distinguished road
Fluid it thicker when cold so some change could be noticeable. Could be the torque converter.
Old Oct 13, 2016 | 04:49 PM
This is my first "truck" in all honesty. I've driven a few old beaters a few times in my life, but in my immediate past I'm coming from a Miata (finely tuned! ) and a Cadillac Deville.. So in reflection perhaps I'm expecting too much?
I really wonder if it sat for a year or more at the dealership and I'm just seeing the after-effects of that. When I got it I changed all fluids, did flushes where I could, new synthetics, changed rotor/dist/plugs/wires/tires/shocks... etc..
Other than the tranny oddity and a slight uneven idle, runs pretty good. Next on the list is the injectors since I see the poppets were in this series.
Thanks again for any thoughts! Loving this site!
Conelpancake
May 30, 2013 05:56 PM
jpimp
Nov 25, 2010 11:10 PM
tjoe30
Aug 31, 2010 04:39 PM
gashdave
Dec 13, 2009 06:35 PM
okvortec
Jul 1, 2009 05:58 PM
