Increse Idle Speed?
Old May 17, 2009 | 09:38 PM
Crestwood1001's Avatar
Crestwood1001 is on a distinguished road
Default Increse Idle Speed?
Is there anyway I can bring the idle speed of my 95 blazer up a little, its the 4.3L Vortec
Old May 17, 2009 | 09:53 PM
rriddle3's Avatar
What is your current idle rpm in neutral?
Old May 17, 2009 | 09:56 PM
I have no idea haha its an automatic and i have no rpm gauge it just seems a little slow and i wanna bring it up just a tad bit
Old May 18, 2009 | 06:08 AM
Define "a little slow"...? Is it stalling out when in gear? Is it acting like it wants to stall out?
Idle speed is controlled by the PCM and is not adjustable without modifying the PCM program.
Old May 18, 2009 | 06:39 AM
oisinirish's Avatar
Ha. But for some frustration you can try manually advancing the timing and watch the computer reset it back for you.
Old May 18, 2009 | 04:54 PM
Say im in reverse and i give it some power and let off the gas it slows down and almost stalls but never has, i think its more EGR related then idle
Old May 18, 2009 | 10:12 PM
Could be a sluggish IAC valve as well or possibly a vacuum leak that has caused the IAC to be closed more than it should be.
Old May 19, 2009 | 03:01 PM
Can i check that myself?
Old May 19, 2009 | 07:27 PM
A bi-directional scan tool would need to be used to adjust the IAC position and monitor the response to idle speed. It should be quick to update.
As far as vacuum leaks, you can attempt to find them with an unlit propane torch. Trace the vacuum lines and intake gasket interfaces with the engine running. Listen for a change in engine sound.
Old May 19, 2009 | 08:39 PM
Its going into the shop saturday for alignment and a fuel filter and lines ill just have they check it out
Pipewrench Dale
Nov 10, 2014 06:16 PM
jdub9000
Jul 22, 2013 07:58 AM
wildboar
May 29, 2006 04:35 AM
DED
Jul 15, 2005 02:46 AM
