Intake manifold gasket
Old Dec 21, 2010 | 10:29 PM
Zerbla96's Avatar
Zerbla96 is on a distinguished road
Default Intake manifold gasket
guess who gets to change his tomorrow so i stop loosing coolant ? THIS GUY
anyone ever do it before how hard is it ?
Old Dec 21, 2010 | 11:01 PM
Frog's Avatar
Frog is on a distinguished road
Doing both right?? Upper and lower??
They are not too bad, just take your time and make sure when you are cleaning off the old gasket material you put some paper towels down over the lifter/cam so you do not get any junk down there.
It would also be a good idea to use a shop vac (if you have one) while you scrape to keep debris from falling to a minimum. Place it right next to the scraper as you scrape to suck it up before it falls.
It might take you the better part of the day to do it to...so, enjoy.
Old Dec 22, 2010 | 06:50 AM
Get the good gaskets! Felpro makes an updated gasket set with a metal carrier (frame) around the overmolded rubber sealing sections.
Search for 'D-tips.com' using the search feature here and you'll find a link to a very well written article plus discussions on this very topic.
Old Dec 22, 2010 | 03:22 PM
Zerbla96's Avatar
thanks
Old Dec 22, 2010 | 11:45 PM
Zerbla96's Avatar
so got the felpro and it took me 5 hours its sooooo cold thank god for space heaters
LJ809
Apr 25, 2010 06:02 AM
kermit1112
20
Jan 21, 2010 11:20 AM
dunontme
Nov 17, 2009 11:04 PM
kiliwizz
Jun 8, 2006 05:54 PM
blazerdan
Jul 14, 2005 12:51 AM
