Intake problems
Old Jan 6, 2018 | 07:52 AM
James Trice's Avatar
James Trice is on a distinguished road
Default Intake problems
I recently replaced the spider injection in me 95 Blazer and put all new gaskets in it when I put it back together. After that I took it for a test drive it worked great. Shut it off changed and then left to go to the store and it just completely lost all power and will bearly run now won't even start most of the time. Anyone have any thoughts
Old Jan 6, 2018 | 11:29 AM
If you have a fuel pressure gauge, the first thing to do is check the fuel pressure. You also want to make sure it maintains pressure after you turn off the key. There may be a fuel leak under the intake manifold.
Old Jan 6, 2018 | 12:47 PM
I just put a whole new fuel system in it all lines new tank sending unit pump about a month ago I checked the pressure about a hour ago it's all good 51psi checked vacuum and checked for leaks around the intake just pulled the egr cleaned and put a new gasket in it I can't figure it out
ComputerNerdBD
Headers, Intake, & Exhaust
Jan 5, 2012 04:53 PM
kermit1112
20
Jan 21, 2010 11:20 AM
dunontme
Nov 17, 2009 11:04 PM
upblazer95
Apr 4, 2009 08:27 PM
Jerseyboy
Apr 27, 2006 03:28 PM
