Intermittent start problems need some help
Old Aug 18, 2013 | 05:15 PM
nas10's Avatar
nas10 is on a distinguished road
Default Intermittent start problems need some help
I have a 1993 s10 blazer, 4.3 CPI v6. Problem is that sometimes, after driving for a while the engine will sputter and die. I have replaced the following
-fuel pump and sending unit
-CPI unit including the regulator
- filter
-fuel relay
-gas tank (had a leak)
- few sensors that has to do with spark
All this I did not to long ago. So here's where I'm at.
After driving for a while it will sputter and die. I check a fuel pressure at the rail and have proper pressure. So I pull a plug and have spark, but the plug was completely dry. I shot some starter fluid into the intake and its tried to fire. After sitting for a while it will start then run like crap and die. I think it's a fuel
Problem but I'm not sure what or what's left to replace! Any help is greatly Appreciated!!
Old Nov 30, 2013 | 08:32 AM
Danielsmith914's Avatar
Danielsmith914 is on a distinguished road
do those have a crank position sensor?
Old Nov 30, 2013 | 09:36 AM
chris015's Avatar
whats exactly is "proper pressure"?
Nothing less then 60lb,then MUST hold above 55 for 10 min. running is around 52-54.
themoneypits
Jul 14, 2013 12:39 PM
Wyatt Abshire
Jul 12, 2012 08:27 AM
fudggj
Nov 9, 2011 08:24 AM
davidluzader
Mar 1, 2010 10:25 AM
scottyk
Mar 19, 2007 11:32 PM
