issue gettin my 99 blazer 4wd 2d started
Old Dec 11, 2013 | 05:54 AM
bryan810's Avatar
bryan810 is on a distinguished road
Default issue gettin my 99 blazer 4wd 2d started
title says it. i have a 99 blazer 4wd 2door, since its started getting cold in michigan ive had a hell of a time getting my truck started only in the morning. after it warms up, its good to go for the rest of the day, i was told the distributor cap an rotor, so i changed that, worked for a momment, ive changed the battery, the coil & ign module, plugs an wires an the cap an rotor. im starting to get irritated, im not a master mechanic but i do alottttt of small end jobs. an can usually figure the problem out. but back to the issue. when i turn the key over, it'll sound nice an strong, it'll crank an crank an crank, some mornings after about 8-10 cranks of turning the key over, it'll start, but not now...; any ideas?
Old Dec 11, 2013 | 05:56 AM
bryan810's Avatar
ooh also ive tried starting fluid an it didnt do anything. thinking its a spark issue. but im not sure. but ive also have changed just about everything that would interfer with the spark. havent i?
Thager
Nov 7, 2013 06:10 PM
mirandaneon
Jun 19, 2013 07:02 PM
DaNK 305
Suspension Tech
Feb 26, 2006 09:27 PM
knightrain420
Suspension Tech
Nov 17, 2005 12:14 AM
zero psi
Apr 18, 2005 11:38 PM
