in a jam
Old 01-27-2013, 10:38 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Grab a hold of your harmonic balancer pulley and wiggle it back forth.Listen for noise in the chain.
Old 01-27-2013, 02:01 PM
rockp2's Avatar
From what I've read on this forum if it's not AC delco ignition parts, all kinds of funky things can happen. But that running smoother than normal thing is curious. I don't know how to test it, but maybe there's a problem with you crank position sensor. Take a look at it and see if the bolt came out, or there's something wrong with the wires. I'm just throwing out wild *** guesses now.
Old 01-27-2013, 02:42 PM
Sounds like a cap & rotor to me. Use AC Delco only! Aftermarket stuff doesn't cut it. Put a dab of silicone dielectric grease on each terminal, inside and out, of the cap.
Old 01-28-2013, 03:24 PM
4x4 canuk's Avatar
4x4 canuk is on a distinguished road
well i finally got er goin last night. at the expense of looking stupid ill post what happened. nothing worse than reading a post with all the same symptoms and no answer. so i bought a new cap and rotor, not delco only because i live in a small town and you need to order that kind of stuff. put in new cap n rotor still no start. much more of a sputter but no start. scratched my head for a bit and did another fuel pressure test. pump was working good, but the regulator i put in was leaking. so once more i pulled the plenum and swapped the reg from the original back in. of course i broke the gasket for the injectors on the last pull out, so i gummed that up with some rtv (again, small town) once it dried she fired right up and ran mint. ive got a new gasket and delco cap n rotor on order. all should be well now i thank everyone very much for all the help. hopefully this post helps someone else out. MAKE SURE YOU HAVE A NICE BLUE SPARK! orange isnt enough. thanks again.
gatorboy44
11-28-2011 11:55 AM
degaine_designs
08-30-2010 02:06 AM
aspenpup
08-04-2009 01:08 PM
avfrff
11-16-2007 07:23 AM
XBlazer01
07-06-2007 07:51 PM
Quick Reply: in a jam
