Limp mode
Old Feb 2, 2022 | 02:25 PM
Austin12242's Avatar
Austin12242 is on a distinguished road
Default Limp mode
I have a 98 blazer 4x4 and I replaced all the solenoids in the transmission hoping it would fix the issue but it didn’t it won’t go out of second gear it just revs and stays in second and around the same time that happened I got a battery light on I had everything tested and it was fine the only codes I have are p0147 P0146 I haven’t messed with that much yet but any help would be good also the outside temp, gear selector, and 4x4 indicator lights stoped working all around the same time as it went into limp mode.
Old Feb 2, 2022 | 09:42 PM
GeorgeLG's Avatar
Check the following fuses:
Clstr fuse, 10A IPFB
Oxygen fuse 20A UHFB
BTSI fuse 10A UHFB
George
Old Feb 5, 2022 | 03:57 PM
Default Checked them none are blown
BTSI fuse 10A UHFB
George
Sorry new to this site I normally just read thru .
Old Feb 6, 2022 | 08:51 AM
GeorgeLG's Avatar
Let me know if I can help any further.
George
Old Feb 6, 2022 | 09:53 PM
Default Limp mode
George
still just not sure where to start with this I did see the wires to the battery was corroded a little do u think the cables could be bad there’s non on the connections but it looks to be in the wire
Old Feb 6, 2022 | 10:06 PM
GeorgeLG's Avatar
What was the result of checking those three fuses?
George
Old Feb 8, 2022 | 09:59 AM
George
they are all still good I checked all three and looked over the others to see if anything looked messed up but there all good
Old Feb 8, 2022 | 10:16 AM
GeorgeLG's Avatar
This may be a wiring problem since the fuses are ok. Did the O2 sensor codes also show up at the same time or were those before the transmission problems?
Do you have and know how to use a digital multimeter to do some testing?
George
Old Feb 8, 2022 | 05:54 PM
George
i have some basic knowledge if not google can help me figure the tool out I have a scanner that can read some some stuff from them
Old Feb 8, 2022 | 10:12 PM
GeorgeLG's Avatar
The power for the shifting solenoids comes from the Clstr Fuse which also powers some of the dash indicators. I had hoped that the fuse was blown, explaining the loss of power for those items common to that power circuit. Since that is not the case, there may be a wiring problem in that power circuit downstream of that fuse or before the fuse. First check that 12v is coming into that fuse with the ignition in the run position. Then check to see if 12v power for the solenoids is making it to the transmission connector from that fuse, I suspect not. You will need to remove the connector and probe pin "E"/pink wire on the harness side with the ignition in the run position. Be careful not to damage the connectors by forcing large probes into the socket connectors. Report back.
George
