loses power when warmed up
Old Jun 14, 2012 | 03:04 PM
Originally Posted by BigBlu102
I have the same kind of problem with my 93. But it also runs rich. I have no check engine lights. Would a 93 compare to a 97 in any way?
93 & 97 use two totally different fuel delivery systems and computer controls, with totally different diagnostic & repair procedures along with different specifications.
Fuel pressure and leakdown should be the first thing to check on both systems. It's free and it only takes about 15 minutes. It's a comprehensive test, (covers several components) and the results will tell if the fuel delivery system is working properly. On your 1993 (W engine code) CMFI system: ignition on, engine off, fuel pump running, pressure must be 55psi to 61psi and must remain above 50psi for at least 10 minutes after the pump shuts off.
Jeffqmc
Oct 25, 2012 09:02 AM
MattP
Oct 20, 2012 05:17 AM
BigBlu102
Feb 23, 2012 12:41 PM
ukneeldownb4me
Nov 18, 2011 08:59 AM
dardamar
Jan 20, 2007 12:42 PM
